XG-100M
KC2TJS
Hello,
I'm trying to setup an HHC-731 with a XG-100M radio. How would you hook up the speaker when there's no audio connector on the brick? According to the manual it appears that you need a CA-012349-007 speaker accessory cable. Which does not appear to be available at the moment any help would be appreciated.
73s,
KC2TJS
BigLebowski
Piedmont NC
KC2TJS
I will have to check that out. Does anyone have a wiring diagram for the 44 pin connector for a speaker only setup. Thanks
KC2TJS
I have already picked up an CA-018399-001 control head cable and HHC-731 microphone. It’s my understanding that you need to get the radios audio output through the 44 pin connector on the back of the radio?
prcguy
I use the 44 pin connector. Pins 19 and 20 tie together for one side of the speaker and pins 21 and 22 tie together for the other side of the speaker. Do not ground any speaker connections.
KC8ONR
bridgeport
yep , you are right. I had a brain fart. I had a HHCH but hated it.
merlin
DN32su
I had an HHCH on a M7100, didn't care much for it, went back to a system head.
Probably the same if I got an HHC-731, but they are far more expensive.
merlin
DN32su
Really? I have the HHC-731 in my jeep and love it. Sure its a little bigger than a Motorola 03 HHC but its rugged and works great. I made my own interface box for about $20 and that works great also.
Personal preference I guess.
KC8ONR
bridgeport
I know this is gonna sound petty , But I didn't like the way the volume worked.I had to keep pressing the button for it to go down or up , Couldn't just hold the button. I know , lame right?
prcguy
A Motorola 03 HHC is a little more refined and I recently swapped out my 100M with HHC for an APX8500 with 02 HHC and I'll admit it was a little nicer. But after a week of seeing that more expensive looking head in the Jeep and thinking how pissed off I would be if someone stole my APX, I put the Harris back in. If someone steals the entire Harris 100M with head I'm out about $700 and I have plenty more. Can't say that for an APX.
merlin
DN32su
Yea, squelch too. most is steps, no repeat.
merlin
DN32su
Seen idiots steal control heads thinking it was the whole radio. Still an expensive setback.
