XG-100P Bluetooth Enabled in Personality Until Activation
firemedic19
Oberlin, OH
Hello everyone,
I just picked up a BNIB XG-100P. It has the latest firmware and is being programmed via Bluetooth using RPM14. I set up the personality and have Bluetooth enabled in the settings, however, when I transfer the mission plan to the radio via Bluetooth, and then activate it, Bluetooth is no longer enabled on the radio. So I have to wipe/reset it to be able to program it again. I am a Harris noob, and I feel that I am missing something very obvious. Any help is greatly appreciated. Thank you!
prcguy
Congratulations, its a great radio. I think all you have to do is go under options in RPM and under bluetooth click enable. Then after its programmed with that feature the radio should always power up with bluetooth active. You can also go into the radio menu under settings and turn bluetooth on.
Hello everyone,
I just picked up a BNIB XG-100P. It has the latest firmware and is being programmed via Bluetooth using RPM14. I set up the personality and have Bluetooth enabled in the settings, however, when I transfer the mission plane to the radio via Bluetooth, and then activate it, Bluetooth is no longer enabled on the radio. So I have to wipe/reset it to be able to program it again. I am a Harris noob, and I feel that I am missing something very obvious. Any help is greatly appreciated. Thank you!
firemedic19
Oberlin, OH
Thank you! Both boxes under bluetooth are checked, but each time I've activated the MP, the Bluetooth option in the radios menu system is greyed out.
firemedic19
Oberlin, OH
Its the mission plan that needs to have bluetooth enabled in the options so when you load it the radio keeps bluetooth on.
Is this the section you are talking about?
firemedic19
Oberlin, OH
That's what's enabled in mine. I also looked in the power up options and there is no bluetooth choices there.
Copy, I have it enabled as shown, but it seems to change whenever its uploaded to the radio. I searched everywhere for a solution before asking on here. Hopefully someones experienced this. Like I said, its probably something super simple that I messed up.
