XG-100P RPM question
rescue161
KE4FHH
Hubert, NC
#2
I can't speak for RPM12, but you may need to revert the firmware to something compatible with 10B. We went straight from 10B to 14 and it does cause issues for ours if we try to just program with 10B using newer firmware. So if we need to use 10B, we revert the firmware to R02A and then program away.
#8
The manual for the XG-100p (Rev R) seems to indicate that R3A is compatible with RPM10B.This is what the manual states.
In XGP R3A and later, the A/B/C switch can be programmed for multiple functions using RPM10B or later.
