n9ihx
Having an issue programing myXG100p. I have a XG100m also that I programed the same mission plan and its working great. I programed my xg100p which has the options needed such as trunking , P25, and wideband enabled. The issue is when I try to scan conventional freqs such as ham, marine, and railroad I get an invalid channel alert. That issue only happens when I add a trunking system to the mission plan. . If the conventional channels are the only ones in the radio they work fine. If the trunking is added the systems all work correctly the trunking works fine but I can't scan the conventional. The same freqs entered in a p25 system work correctly and will scan. Also gmrs channels work correctly. The exact same mission plan in my 100m works correctly. I locally entered all the freqs I didn't just dump the mobile plan in and the issue is still there. Its probably something stupid been thru it a bunch of times and can't find anything programmed incorrectly. Wondering if anyone has seen this before and may have the solution.
Greg...N9ihx
Greg...N9ihx
