XLT2500 help
RadioChief55
Looking for some help with a XTL2500 I just got back from the depot.
I'm using the latest CPS and I have a OEM Moto USB cable.
I get this message on the remote head (maintenance mode remote device) When I try to write or close through the CH I get (open radio failed error context 24) I hook up the the brick and tried to write/clone and flash and nothing. I know the CH and wiring is correct because I have a spare unit in place of the one that went out for repair and it works fine. I looked at forums and it's the same thing over and over without any solution, if I missed a post with a solution please post it here. Thanks
crazyboy
NJ
Provided power is correct, sync the control head with the transceiver.
RadioChief55
I did, it works fine with the spar brick I have in it, when I put the repaired (original unit) in I get the message.
