XPR 5550 with L3208 Junction Box
dpridy
I am the IT guy here at work and now the radio has fallen in my lap and I am lost.
We have an xpr 5550 connected to a GIA-Tronics ITA2000 tone remote adapter we had 2 GIA-Tronics ITR2000 tone remotes they have both died over the last year and are out of stock until 2022.
The "radio guy" said any tone remote would work so I picked up a Moto MC3000 (digital) it can receive but not transmit, so I nabbed IDA 24-66 (not digital) it can key the mic but not transmit...I think. Now I just got a Moto Digital Junction Box L3208 to run the MC3000 but I am not sure how, or even if it is possible to connect the two. The XPR has the accessory port and the L3208 has a DB25 port can they be connected? I keep throwing small amounts of money at this and waiting for items to arrive but not getting anywhere.
Can anyone point me in the right direction? Should I just wait for the ITR2000 to come back in stock?
cpg178
I toyed around with the MC3000 and a CDM1550 and MCS2000 earlier this year. It is to my understanding that the MC3000 is for CDM1550, Astro Spectra and MCS2000. I know earlier this year @rescue161 posted his setup with an MC2500 controlling an XPR5550. They may be able to provide some insight.
Firebuff880
Boynton Beach, FL
Depending on your mission / budget you might consider a Telex solution with an IP-223/224 Panel for the donor radio and IP-2002/IP-3002 for the remote consoles. The 3000 series is the newly announced replacement for the 2000 series.
R8000
Very Low Battery
The MC3000 was meant to work with Motorola's SB9600 protocol. I don't know for sure if the XPR radios will support SB9600. That's digging deep into a real mess.
Your radio guy is correct. If you have a tone remote adapter on your radio, any tone remote will work....as long as it has matched settings to what your tone adapter is wanting.
Tone remotes can come in either 2 or 4 wire models. Some have programming dip switches that can change this, and some need to be factory ordered 2 or 4 wire.
The function tone tables have to match. Unless there was some weird special thing going on, the industry standard tone table should work for a simple single channel setup. 1950 Hz F1, 2050 Hz monitor, 2175 Hz HLGT.
2 or 4 wire ? If you need duplex audio to your remote (between the radio and the remote) such as a permit to talk tone, then you need 4 wire. If you use a simple conventional analog system, a 2 wire remote will do just fine.
Since you are not a radio guy and just want it to work, put the tone remote stuff back the way it was and purchase a tone remote. You don't need and IDA remote. CPI makes decent stuff that can do the job for you.
If you want to cobble digital stuff into it, I am not going down that path. That's like walking someone trough doing a DOD delete on their Chevy truck.
Or... you can just have your radio tech make it all work again :)
Good luck !
CPI Remotes
dpridy
Thank you everyone, sounds like I just need to find the right combination of jumper and switch settings to make what I have behave. I'll stop buying random equipment off ebay now.
