XPR 6350, 6550 Program Priority Override.
Fracker
All over
Hello,
I have crews with 6350's and 6550's i want to know how to set the radios so that the supervisor radios can override any conversation that is currently TX, for example if the guys are babeling about random stuff and a problems happens a suppervisor can key up and brodcast so the crew can hear even though one guy is all ready talking.
Any help would be apreciated.
Fracker
All over
Is that under the channels propertys? Allow Interrupt and Transmit Interuptable Freq? also is there a way to set difrent levels? For example if a Manager shows up and he wants to key up can he override the supervisor ?
thassler
Tennessee
There's a few ways to do it.
Under the channel properties you can set the Admit Criteria to 'Always' and the In Call Criteria to 'TX Interrupt'. As long as all the other radios have the 'Allow Interruption' checked they will be de-keyed when a supervisor transmitted. I would probably make this a separate channel that a supervisor had to change to when they needed to de-key someone because it takes longer before you can start talking.
A second method is to program one of the buttons to 'TX Interrupt Remote Deky'. When pressed it will de-key any other radios that are transmitting. On our 6550 radios I program the blue side button1 'long press' to issue a remote de-key for our supervisors.
There's no way that I know of to set levels. When a TX Interrupt is issued it doesn't care who you are as long as the 'Allow Interruption' is checked.
Fracker
All over
Help
OK on my
6550 i have set the
Allow Interruption Uncheck
TX Interruptible Freq Uncheck
Admit Criteria- Always,
In Call Criteria- TX Interrupt.
On the 6350 I
checked Allot Interruption
TX interruptible Freq Unchecked
Admit Criteria to Channel Free
InCall Criteria To Always
If the 6350 Is keyed up and i try to key up on the 6550 nothing happens, i push blue button for dekey it says failed.
what am i doing wroung My moto CPS is version 7.6 build 384
