Xpr 6350
eyes00only
Denver Colorado
Why can't I capture the frequency of this radio (Motorola XPR 6350) with my Pro83 or PSR500?
This is the first time I've held the freq. counting unit inches from any transmitting
unit and not getting any readout. WTH ?
JK
gary123
the radio is constantly transmitting and unkeying. this break in the signal is enough to mess up frequency counters and close call circuits. If you are close enough a close call will work but you almost have to be sitting on the antenna.
the best way to locate a TRBO signal is to search the freq band where you think the signal is. Using lockout in search will eliminate know or unwanted signals.
eyes00only
Denver Colorado
Is the way the radio is supposed to work? I guess that's what they mean by digital. The antenna has VHF on it. I had the counter an inch from the antenna. I also tried your other method by searching 150.000 to 154.00 but will try that again. Thanks
for the reply sir.
JK
davidgcet
if it is in digital mode then it is using TDMA and thus every few microseconds it unkeys to "share" the channel with another user. your scanner cannot decode TRBO anyway, but you can use a disc tap and run DSD to do it.
crazyman28
Fairfax, VA
I hate to bring up an old thread, but just to clarify from what I have read, you CAN NOT scan (pro-106) a Motorola XPR 6350 if it is transmitting digital?
N1XDS
ÆS Ø
Correct, you can decode MotoTRBO transmissions on a digital scanner unless you preform a discriminator tap and use a program that decodes MotoTRBO digital transmissions.
gtaman
TACSAT
GALAXY 19 91.0° W
I found mine by using signal stalker. Just searched uhf and then I heard the digital noise. Un keyed and key up again to make sure it was the freq and it was.
ramal121
Lots and lots of watts
Calif Whine Country
It depends on what you are trying to receive. If the TRBO radio is transmitting to a repeater, it will be pulsed on-off and a freq counter will not lock on to it. A scan type scheme maybe will catch it. Now if the radio is transmitting on simplex, it will be a constant RF transmission and anything should be able to sniff that out.
crazyman28
Fairfax, VA
Thanks for the responses.
So, using stalker I am able to find that the radio frequency the XPR 6350 is operating on. However, it is just digital static. Is there anyway to actually here the transmission?
N1XDS
ÆS Ø
On your PSR-500 you'll have to or someone you know will have to do a discriminator tap inside your radio then download a program that you can find out the color code and talk group the people are using.
gtaman
TACSAT
GALAXY 19 91.0° W
You would need a discrimiter tap to actually "hear" the audio. But to find the freq you hear the digital noise that is just as annoying as p25 on an analog scanner.
JRayfield
Springfield, MO
Actually, that is not the case, with respect to simplex operation.
When a MOTOTRBO radio (or any DMR radio, for that matter) is transmitting in simplex mode, the transmitter is still being 'pulsed' on and off. In fact, the latest firmware for MOTOTRBO units allows them to sync between themselves in simplex mode, so that they can operate in a 6.25E mode (6.25 khz equivalent) without using a repeater.
John Rayfield, Jr. CETma
ramal121
Calif Whine Country
Yes, you are correct. My reply was clouded with visions of FDMA dancing before me.
62Truck
Ordinary Subscriber
Uranus
Part of that statement is not true. P25 phase 1 doesn't pulse on and off like trbo. P25 phase 1 is a constant carrier when the ptt is keyed.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
No, P25 has nothing to do with DMR.
DMR refers to radios built to a specific ETSI standard which P25 radios are not.
62Truck
Ordinary Subscriber
Uranus
I apologize for my miss information then. That I didn't know.
