Hi there,
From MotoTrbo CPS 14.0, I'm trying to adjust the backlight timer setting on my XPR 6550, so the backlight stays on all the time when activated (right now the backlight works, it just goes away after a few seconds). The CPS help menu states there is a Backlight Timer setting in the Menu. It says "This checkbox allows you to enable or disable the Backlight Timer menu. When you enable this checkbox, you can set the timer for the Timeout Timer feature in the radio via the menu."
However, I can't find this setting in the actual CPS. It's almost like my version of the CPS doesn't have the backlight timer setting activated. Can someone clarify where this setting is found, and if it's available in CPS 14.0?
