XPR 7550e Vibrating Clip firmware bug found
#1
Anyone know if this is known issue or if it has been addressed?
When using the vibrating belt clip on a new XPR 7550e when imitating a private call to a contact the battery vibrates when it shouldn't (It's not an alert and the alert sound shouldn't and doesn't sound).
R02.06.05.0002 is this current?
