XPR-7550e Wide Band Entitlement
DavidBachus
San Antonio
I may have fouled up my installation of the 20/25 kHz Channel Bandwidth upgrade. I am using CPS 2.0. I believe I activated the Wide Band Entitlement and see it listed in Activation Features. I was interrupted during the installation process and when I went back to it I can't make my way back through the process to fully complete the upgrade. Any advice would be appreciated. I used to be pretty good at programming Spectra's, but MS-DOS was a long time ago.
Thank You
David/K5AQS
WM7C
Bakersfield, CA
You should see it under "Licenses> View Application Licenses". If it's not there, you would need to add the EID under "Register Application Licenses".
DavidBachus
San Antonio
Thank you for your reply. This is what I have:
The purchased entitlement does not show up under the radio's features.
Any further suggestions?
WM7C
Bakersfield, CA
To add, the entitlement is bound to the computer you used and does not follow a radio. I was hoping I could use a VM with any further EID, but I could not read a radio in WMware Player. I might start a new thread.
DavidBachus
San Antonio
My channel bandwidth is now correct; perhaps all along. I do not see the entitlement listed in Features. Thanks for your help. As you can see for sure I am a newbee on more modern programming on Motorola.
Thanks Again,
73's
