XPR3500e cable
K6GBW
Montebello, CA
Can anyone confirm that the cable to program the XPR3500e is the same cable as used with the XPR7550? A reference online indicates its the PMKN4115B and I just need to confirm that.
Thanks!
K2NEC
5F6
No it is  not the same cable. Completely different connectors. PMKN4115 is the correct part number, but this is not the 7550 cable.
K6GBW
Montebello, CA
Thank you very much gentlemen. I just ordered the proper cable. I have an XPR3500e enroute. I've used 6550's and 7550's before but never the 3500 series. I'm planning to use it on a local DMR repeater network that have amazingly good coverage here in the L.A. area. Hopefully the smaller size will make it easier to tote around.
Again, thank you all!
