XPR5550 on-off
J
jerryray
Guest
The XPR5550 has a soft start for turning the radio on. I built a cable for the rear accessory that allows programming and Ignition sense Pin 26 of the connector (so I was told). This sense lead goes the 12v
I set he ignition sense to On/Off or ignition option under accessories. Programming part works OK.
I thought when power was applied to the radio plus the sense wire, the radio would come on.
It does not. I was told to set this option to follow ignition only. I am concerned if I do that and the sense circuit is not working correct I would not be able to turn the radio on.
Anyone set theirs up this way?
firefive76
Kansas
The main power wires on the radio need to have constant power, not switched. Only the ignition wire should be switched.
EDIT: Also, the ignition sense pin is 25, not 26
