XPR7550 aftermarket programming cables "any good "
SD70MAC
NC
TLF82
Texas
If you have a XPR7550 ,do you use a aftermarket programming cable ? Which ones are good ?
one I looked at;
Amazon.com: SUNDELY® High Quality USB Programming Cable For Motorola Radios DGP4150 DP4400 APX7000 XPR6380: Car Electronics
I have a OEM PMKN4012a and it is not so good. Sometimes it will connect to the radio sometimes it don't. I may just buy a OEM "B" revision ,but I wanted to see how the aftermarket ones are performing.
Windows 7 PRO
12.1 CPS
2.50.04 FW
For $80 I would just buy a OEM cable and not have any worries.... My radios cost too much to chance them on an aftermarket cable.
PACNWDude
I have used many of the radio programming cables sold on auction sites. I try to get the ones with serial connectors rather than USB as they seem to work more reliably.
For Motorola Trbo radios, the Kawa PMKN4012 cables have worked for me. Just use Device Manager to see which port they are trying to use, and set the for USB COM1.
N4KVE
PALM BEACH, FLORIDA
That's strange. I use the "A" cable on my 7550, & 7580 & it's 100%. While mine is unmodified, there is a simple modification should the "A" cable not play nicely with the 7550.
N2AL
Tennessee
one I looked at;
Amazon.com: SUNDELY[emoji768] High Quality USB Programming Cable For Motorola Radios DGP4150 DP4400 APX7000 XPR6380: Car Electronics
Windows 7 PRO
12.1 CPS
2.50.04 FW
I generally try to purchase serial cables, then use a Serial-to-USB interface to program my radios. If I cannot purchase a Serial-to-USB cable, I will purchase an FTDI USB cable. The FTDI chip in the USB cable is fantastic for Windows and Mac operating systems. The cheaper online resellers on eBay for example, do not have these chips and they will not function correctly on computers.
Andrew | N4AWL
www.n4awl.com
ElroyJetson
I would never recommend using an aftermarket programming cable when the real deal, which will NOT brick your radio, is pretty reasonably priced.
You have an expensive radio and you want to take a chance on a cheap cable that can turn it into a brick? What's wrong with that thought process?
TRENT310
The XPR series are natively USB so there isn't a USB Serial converter. They show up on the computer as a USB Ethernet adapter.
I only ever use a cable with XPR7550s on firmware load procedures, or on XPR7550IS models that don't have Bluetooth. Otherwise pairing via Bluetooth is often easier and runs at the same speed anyway.
rabrol
Edmonton, Alberta
I have been using a $21 cable from China with no problems on Windows 10. Works great with the XPR6550 and APX radios I've had access to.
Found it on eBay.
I ordered a SUNDELY cable for my ICOM and have had no problems with it either. It is using the Prolific 2023TA chip.
I've been very pleased with the cheaper programming cables I've used.
Sent from my wx_na_wf using Tapatalk
