XPR7550 cloning
MedicDavid78
The Astro25mosP25ere
#1
I am curious about something. I know with cloning a radio it has to be the same model radio as the radio being cloned, however, is there a way to clone or somehow copy the codeplug systems and info from an XPR7550 into an XPR6550? I don't see an Import/Export option like ASTRO-25 CPS or MTS2000 CPS has... Thanks!
n2hbx
Orlando, FL
#3
Difference being, unlike the Astro 25 CPS where you open two instances of the the CPS and D-D between them, you open both TRBO codeplugs in the same CPS session and do the D-D.
Larry
MedicDavid78
#4
Okay, that answers one question. Now it creates another: because I would be dragging codeplug & system info from 1 model radio & dropping it into the codeplug for a different model radio, would I get a error for trying to write another model radio's info? Or would the drag & drop automatically adjust the system info to format the radio I am writing? I hope I didn't confuse anyone, LOL!
Midlothian, VA
#5
If anything is not compatible, you'll get a warning that anything different will be set to default values but it'll still allow you to. Obviously, best to check everything once you're done to see if any values you didn't want to be defaulted are OK or if they need to be edited. Most parameters can be copied over with a big exception being Receive Group Lists. You'll have to recreate those.
MedicDavid78
#6
Alright I will give it a whirl. Thank you to Gary (N4KVE/MoonBoots) and the rest of you for your prompt quick replies! It's much appreciated!! DMR is a whole new wasteland for me, I can to ASTRO-25 stuff in my sleep but this DMR is tricky, especially Connect+ and Capacity+ stuff...
N1GTL
CT
#7
CUT and PASTE works GREAT with MotoTRBO. It works between mobiles, portables, models numbers, etc. I wish ASTRO and APX worked as well.
