XPR8300
Jl942264
All,
Just inherited an XPR8300, plugged it in and it booted right up. Tried to read it with CPS16 and its giving me the "make sure you're using the proper cable" (which I am and my CPS is legit from MOL.) The computer recognizes it, in the device manager, and it comes up no problem when I plug it in. I cleaned the contacts with an eraser, and alcohol, and compressed air. No dice. I'm thinking firmware?? Any help is appreciated!
kg6nlw
Railroad & Ham Radio Extrodinare
Sonoma Co., California
Are you plugged into the proper port? If I remember those had TWO connections that were similar for "output/programming". Also, is it showing up as a NETWORK DEVICE not a COM PORT on the computer?
Regards,
-Frank C.
Jl942264
I’m not sure what port it’s connected too, where would I tell the difference. It comes up as a network device.
kg6nlw
Then it would be in the right port if it comes up as a network device on the computer. Make sure the drivers are current. I know the 8300 had power issues.
Regards,
-Frank C.
Jl942264
Update!
got into it, firmware issue! Thanks all!
