XTL 1500 Alerting Day Night Mode
erico
Tracy, California
Is it possible to program an XTL 1500 with a "Day" channel and a "Night" channel where day squelch is open to hear traffic, and night is muted until an alert is received then radio/dispatcher traffic is heard?
Radio system is UHF conventional P25. We are using astro id for alerting.
Thank You
Eric
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Thank You
Eric
Yes, just program two separate channels appropriately.
erico
Tracy, California
We have programmed a day channel that alerts correctly and allows audio to pass. The night channel we programmed is muted and alerts, but radio traffic audio does not pass through after alert. The radio stays muted. The only thing audible is the alert tone. Any thoughts on settings?
AK4PY
It can be done, and you are close. I suggest you call your radio shop and pay them to do it. This is the type of service they provide and you don't have to guess at it.
MTS2000des
5B2_BEE00 Czar
What he said. We are currently retrofitting our fire stations with a backup alert using Call Alert paging. The local shop is using a combo of APX/XTL consollettes and relay controllers, and adding day/night switches that will route/cut audio to the station house PAs. It is not difficult but requires more than just programming radios.
erico
Tracy, California
I already inquired with the local shops. They advised they are not sure it can be done on ASTRO.
erico
Tracy, California
Thank you for input. Our stations are set up with relay controllers to switch between day and night. My inquiry is whether I can do it with the radio by selecting a day or night channel and eliminate the relay controllers. In Quick Call it is an And/Or setting. In Astro that option is not available. Was wondering if there was a different setting. This station only needs audio, it does not need lights , gas shutoff, etc.
