XTL 2500 vehicle setup
jnasium21
Hello all. I have a coworker that wants to be able to listen to our frequency when he is not at work on a personally purchased radio installed in his personal vehicle. He said he does not plan on ever transmitting on it (part of our rules from our director). He wanted to know if he could plug the radio into his cigarette lighter, since the specifications only say it draws 3.2amps when receiving audio.
N4KVE
PALM BEACH, FLORIDA
If your friend is a salesman flying to different locations, & renting cars all the time, I’d say, yeah the liter plug, & a magnetic antenna. But if this is going to be permanently in the same vehicle, go to the battery. Many liter sockets in newer cars aren’t for lighting cigarettes. They’re for powering your phone, or other low power devices. I used a liter plug for a while during a lazy period, but while at a red light, car in gear, A/C running the radio would get stuck in transmit. Finally I connected it to the battery, & it never happened again. And that was a liter socket.
12dbsinad
It's only a 45W model, and he said he never plans on transmitting.
Would be fine for RX. I would never recommend a cig lighter for TX even a low power model set at full power. They get hot (spring contact) fast drawing that kind of current and some 12v outlets are only fused at 10amps.
jnasium21
That's what I was telling him. He had no intensions of transmitting anyway, he wanted to be able to listen to work on his way in (he travels in from a distance where portables aren't suitable) so he knows what to expect for the day. I appreciate your response. Do you have a specific cigarette lighter XTL2500 power cable that you would recommend?
12dbsinad
If he has a power cord, he can just purchase a 12V male outlet and install/splice it in. If he needs a power cord, I'd just find a cheap one on Ebay personally. Motorola does make a OEM one, HKN6548A.
jnasium21
Awesome. Thanks so much for your help!
ten13
ten13
Just a note about cig. plugs:
I have a ten-year-old Honda Pilot. When I first got the car, I sat a Motorola CDM on the seat next to me to monitor, until I got the radio permanently and properly installed.
One day, I accidentally hit the mic button, expecting a blown fuse. It didn't happen. I found out (from a sticker on the cig. receptacle) that the cig. receptacle was rated at 120 Watts. The car has three of these 120W receptacles.
I would imagine that newer SUVs (at least) have higher-rated cig. plugs also.
natedawg1604
Colorado
My recommendation is to read the XTL installation manual from Motorola, it has very detailed sections about how to install the radio properly in terms of electrical & antenna connections. If someone wishes to install the radio themselves, it only makes sense to look at the installation manual. There is no reason not to....
clbsquared
Isle of Wight County
That’s a max of 10 amps. It may be ok for a short TX. Definitely not something I would use for continuous daily use.
ten13
ten13
All three of the plugs are rated at 15 Amps.
Besides, what else would one be transmitting other than a "short TX"? And just what is meant by "continuous daily use"?: a stuck mic button? I'm certainly not reading a newspaper article over the radio.
In any event, it was a month or so before I got the radio permanently mounted, and there were no adverse situations from using the radio as I usually do.
clbsquared
Meaning, when Motorola designed the XTL series, they didn’t design it for the casual user. It was designed for public safety / commercial use. And it was designed to be properly powered so it could handle continuous daily use.
For the hobby user who just wants to listen, a cig plug would be ok. I never said it wouldn’t.
