XTL 5000 Remote Device problem
nadeera
Negombo,Sri Lanka
My XTL 5000 mobile radio set is power up and display "Maintenance Mode Remote Device". What's it mean and how solve this problem.please help me.
riveter
MD
Are you sure the radio itself is receiving power? That often happens when the control head is on but the radio hasn't actually turned on/received power to turn on. Ensure the radio is receiving main power and ignition sense.
If everything's hot and should be powering on, get to the radio's info or put it in test mode (usually HOME button x5 within 10 seconds after turning it on) and see what the firmware revision is - if the radio's firmware is R17.00 or newer but OLDER than R19.60, it is likely the firmware bug that was in that group of firmware releases.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
With no communications between the head and drawer, he isn't going to see any firmware revisions.
Try reading the drawer from the rear 26 pin connector. If that fails, you've got a bricked drawer.
