XTL1500 800 MHz is it possible to reverse the in/out frequency?
haywire
Los Angeles, CA
Is the 800 MHz radio capable of transmitting on the input frequency and receiving on the output frequency like the UHF model? I am aware that the frequency split for UHF is 3 or 5 MHz where the 800 band is 45 MHz I don't have a code plug to see if the CPS software will accept or reject the attempt to reverse the in/out.
ecps92
Taxachusetts
Not that I have ever seen
You can only put in 851-868.9875 then select if you use Talk-Around
But No you can not put in 806.9875
KE4ZNR
Radio Geek
ECPS is correct. CPS will not allow you to "reverse" the frequencies.
It will just create the dreaded "red" box error and force you to correct the frequency before allowing the codeplug to be written to the radio.
Only option is to use Talk-around.
Marshall KE4ZNR
Could we ask WHY you'd want to do this? Talk around is one thing, completely swapping the TX and RX is different.
slicerwizard
Toronto, Ontario
Pretty sure an 800 MHz radio will have a 851-870 RX bandpass filter. Not much point in specifying an RX frequency in the 806-824 band when the radio is deaf down there.
haywire
Los Angeles, CA
Hypothetical question. No real reason. Although I have seen it done on uhf radios set to low power and talkaround for special events where encryption is not available. The tech reasoned that not too many people scan the input to the repeater.
