XTL1500 FLASHED TO XTL5000 FOR 900MHZ
pewpew45
Good afternoon,
If a XTL1500 in 900 MHZ is flashed to a XTL5000 in 900MHZ will an 03 control head work on it given the TIB was converted for it?
Have one that was flashed to XTL5000 with an 03 control head. The radio receives fine, but when trying to transmit the red light comes on but no TX output going out.
Wondering if it's the setup or something internally on the brick?
wyomingmedic
I've upgraded plenty of 2500s into 5000s with an o3 head. No problem. I've never done it with a 1500 but no reason it shouldn't work.
ElroyJetson
I've never even messed with XTLs so I'm clueless. Am I gathering that the XTL hardware doesn't care what you call it, a 1500 can be reflashed as a 5000 with new firmware? Because I've got a stack of 800 MHz XTL1500s that I haven't even touched yet since I got them. I might want to play with one....if I know what can be done to them.
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
Good afternoon,
No power output or no audio? That configuration should work fine but perhaps whoever flashed it did it wrong and erased the tuning.
MTS2000des
5B2_BEE00 Czar
It requires tools which aren't discussed here. The XTL1500 brick is the same as an XTL2500 and XTL5000- all are identical internally. The only difference are control heads and software.
GTR8000
NY/NJ Database Guy
BEE00
I have done at least a dozen 1500 to 5000 "Upgrades" and all worked great
Have you ever done a 1500 > 5000 conversion keeping the 1500's original MX head? I'm trying to determine if a 5000 would recognize and operate properly with an MX head attached to the deck.
GTR8000
NY/NJ Database Guy
BEE00
Further research suggests that the MX head is compatible only with the 1500. Bummer.
Project25_MASTR
Millennial Graying OBT Guy
Texas
But you can "re-assign" a M5 head on a 2500 as an O5 (and vise-versa) by cutting the button membrane and re-affixing the carbon jumper that defines whether the CH is a M5 or O5 head.
GTR8000
NY/NJ Database Guy
BEE00
Cool, but what does any of that have to do with an MX head on a 5000?
