XTL1500 Programming Cable part #
marcotor
I ♥ÆS Ø
Sunny SoCal
That's it. It's capable of programming multiple radios. using one right now with an XTL2500
TheWarlock
Mississauga Ontario
Thanks. Also when programming do you also require a power supply for it if so what is that part #.
Pro-91, MTS 2000 800MHz, Astro Saber VHF, APX 6000 7/800MHz
sfd119
It's a USB cable, it doesn't need power from anything special other than the computer its plugged into. Unless you're talking about the radio, which needs to be on (12v).
TheWarlock
Mississauga Ontario
Yes I mean the radio. What is the part number for the 12 volt power adapter?
TheWarlock
Mississauga Ontario
sfd119
I don't mean to be rude but these are fundamental radio questions and if you can't answer them, why are you programming?
To answer your question, you'll need a power supply to hook the 12v to the power in the wall. Google is your friend. Astron Power Supply should be a good start for you to start researching.
N4KVE
PALM BEACH, FLORIDA
Mobile radios run off 12-13.8 volts DC. The plug in the wall at home [or anywhere] supplies 117 volts AC current. You will need a 12 volt power supply like Astron, or a dozen other companies make to supply 12 volts to the radio from the wall. Or, you can simply bring a car battery in the house to power the radio. But as said before, this is basic radio 101. Even my wife who knows ZERO about radios knows this.
Astron Power Supplies
TheWarlock
Mississauga Ontario
Thank you all. I'm 19 and have no experience with electricity conversation. Thanks
N4KVE
PALM BEACH, FLORIDA
All this 12 volt mobile radios used in a house requiring a 12 volt power supply was learned while getting my Novice license. Read up on the differences between a linear, vs switching power supply. Good luck.
TheWarlock
Mississauga Ontario
Absolutely. Will do. Thanks.
