XTL2500 faceplate housing
Anderegg
Enter text in this field
San Diego
Is it possible to swap an XTL2500 control head electronics into the shorter XTL5000/O5 black housing? I would like to flush mount a new XTL2500 in a 2 inch space (Havis console) currently occupied by an Astro Spectra, but the XTL2500 head has that stupid flare out on it and won't fit the space. The O5 head is 2 inches high, no flare, so it fits.
If Motorola sells the plastic housing for the O5, would anyone have the part numbers?
Paul
sfd119
I believe you can switch the electronics.
I know theres a little rubber "switch" inside the O5 heads that can trick it into being a 2500 M5 head. A Communications.Support member did a write up, however that site is no longer.
Hopefully someone here still has that write up saved...
Anderegg
San Diego
I saw that...after you remove the back electronic board, you pull out the keypad bar and cut off the little 6th rubber "finger" next to the 5 rubber keys, rotate it 180 degrees and put it back in the hole. Can convert an M5 to an O5 or O5 to an M5 and switch it back at any time. Hoping Moto sells the housing and buttons without needing to buy the entire head.
Paul
Anderegg
San Diego
I have been browsing Wiscomm, but it's difficult to determine what parts are what parts. I know what a button and a lightpipe is, but not having luck figuring out what a faceplate is called. A housing seems to be a remote backing.
Paul
kk6rq
Clear Lake, IA
M5 to O5 Caveat...
Just be advised the actual button rubber bit is different, so make sure you get the O5 rubber, too (one of the posters above indicated the same thing but I just wanted to make sure it was clear). I've done a shedload of these and it works great. Good luck!
