XTL2500 Serial program cable, pinout?
sagacious
check my ip, anon proxy?
I have several XTL2500 serial programming cables that no longer work. Ive been looking into repairing them with new connectors. since the originals are epoxied in i can't see the pinout configuration. does anyone know what it is? thanks.
fineshot1
NJ USA (Republic of NJ)
I don't think that will do you any good. If I recall correctly the serial cable(OEM) has
a level converter circuit either in that epoxied connector or somewhere in the cable.
It is not a straight through wiring setup.
ILMRadioMan
The road to no where.
This is correct for a MIC jack programming cable.
However you can build a programming cable for the accessory jack, on the back of the radio, without any extra parts.
Just a serial connector, and an accessory connector.
I have made many.
If you want that pinout, lemme know.
fineshot1
I have made many.
Good info - thanks, but what do you do if the radio requires +12V ignition sense to power up?
ILMRadioMan
Have a wire for that pin coming out of the connector to hook up to a 12v source.
If you have a 12v power supply, dont just hook up the main leads, but also add in the ign sense.
Do remember that those accessory plugs are pretty beefy.
I built one that could do Serial Programming, USB programming, and ignition sense, all in one accessory plug.
We called it the octopus programming cable.
fineshot1
Thanks again - if you get around to it can you pm me the pinout for that octopus cable - i like that idea.
viet5d
CA, US
I have made many.
Do you know why the Emergency pin is shorted to Ground ? If I want to use the Emergency mode, do I have to cut/separe this signal from Ground ? Thanks
