XTL2500 Symbol
IMPRES2
What does this little symbol mean? It only likes to show up in the mornings when I leave for work and then disappears roughly three hours later around 8:00 AM (EST)
S
SARCommCoord
Guest
I see you are in Chuluota, I am just down the ways from you in Winter Springs. What are you monitoring when the symbol appears? On my work XTS 3000, that symbol shows up on frequencies that are open CSQ. When on a channel that as toned squelch, it is not present.
IMPRES2
I'm actually on my own licensed frequencies and I sat here for roughly 7 minutes off of 17/92 and Semoran at the Northerntool and went to pickup my mic (HMN4079C) and the symbol came on, I placed my mic back on the clip and it went off... So I thinks it's a PL Hub delete.
What do you do that you have an old XTS3000? I have two XTS5000 handhelds I use and am about to snag myself an APX8000.
S
SARCommCoord
Guest
Wildland Fire Medical Unit Coordinator for 501(c)(3). We provide medical teams under contract for wildland fire operations, trainings, rx burns etc.
IMPRES2
I've seen you before!! You assisted the MVA and looked to be first on seen right across from the Macaroni Grille there off of Mitchell Hamock, at least I think that was you... It was about a month ago maybe....
After poking through your threads I noticed you are a UHF listener. With R/M being transferred you might lose them!
Do you monitor all the local traffic UHF wise?
S
SARCommCoord
Guest
About a month ago I did stop at a wreck at Mikkler and Red Bug Lake Road, which is near the Macaroni Grill. I usually monitor VHF (Forestry, State and Federal) but monitor UHF for DMR and the SARnet system. As for R/M, operations will remain the same. The merger will not be affecting anything operation wise, however, R/M is working on going MotoTRBO
IMPRES2
What a crash that was, this back and forth of post is annoying, send me an email letting me know it's you, also a bit more private for frequency details!!
djlolli@yahoo.com
ecps92
Taxachusetts
Yes - PL on/OFF aka CSQ
When you take the Mic OFF-Hook the system should (if correctly programmed) Open Tone, so you could hear if others were using another tone (Community Repeater) and not transmit over them.
sfd119
It is PL Hub defeat if it is happening when you pick up your mic.
