All,
I have searched through the boards looking for a solution, and so far I am still having difficulty--
I recently acquired a couple of XTL5000 units at auction from a local municipality. The one in question is a remote set up with O5 control head. The control head and radio body were both removed from active service, working at the time of removal (supposedly). The remote cable and control head power cable were not included, so I purchased these new, OEM. When everything on the body and control head is connected and powered up, (including ignition circuit) the control head displays FL 01-90, cycles off/on and displays the same fail code before lighting up in Maintenance Mode Remote Device display. I can read, edit, and write to the radio without difficulty from CPS, so the brains seem to be fine.
From my reading on the forums, this type of issue seems to be a connectivity issue between the radio and control head, which makes sense. I of course have tried unplugging/replugging everything. Interestingly, I can use the power key on the control head to actually turn the radio on and off (evidenced by the radio connecting and disconnecting from my computer with the programming cable attached to the rear port). I have already unseated/reseated the flex cables in the remote kit on both ends per recommendation of previous fixes in my research. This has not fixed it. Additionally, the radio actually did completely power up and display just one time during my testing before immediately going back into this cycle of failing. (Which certainly made me suspicious for a poorly seated connector.)
Suggestions? I'm not sure if a "control head sync" would be helpful in this instance; I do not have the front control panel attachment programming cable, so I have been unable to attempt this. Thanks in advance for any expertise thrown this way!
