XTL5000 remote to dash mount
smorris
Stroudsburg, PA
Hello everyone,
I purchased an XTL5000(M20QSS9PW1An). It is set up as a remote mount, less the control cable. I want to convert this back to a dash mount. I took off the interconnect boards on the control head and the radio and tried to mount the head back on the radio but, it would not work. Do I need an adapter sleeve of sorts or is this particular model only capable of remote mount?
WX3PMC
W0JJK
3085020F03 is the dash flex. It replaces the remote flex.
W0JJK
Ok I have that parts you need in my office. I can you those numbers Monday.
W0JJK
Here are the parts you need.
HKN6192B is the Flex
1585245E02 - - Thi plastic piece is plastic piece.
smorris
Stroudsburg, PA
Thank for the info. I just found out that after I convert it back to dash config, I’ll still be required to go into the code plug and change the head type to dash and unfortunately, I don’t own the CPS. I’ll just have to keep it a remote mount. The Spectra was so much easier.
WB6WQF
If you don’t own CPS then how do you program the radio?
BigLebowski
Piedmont NC
An O5 is an O5 whether it is remote mount or not. The only programming change required is if you switch to an O3 or W-Series head.
W0JJK
I just made a remote mount to a dash mount by removing the TIB and remote flex.
I installed the plastic ring and than the dash flex. Last I put the screws back in and it works without any reprogramming.
