XTL5000 TIB Ident.
KK7GKG
Salt lake county
Hello All
I recently acquired a XTL5000 without an Tib on it
When I tried to attach an XTL2500 TIB cable it did not work
I've attached a photo
Model: M20QTS9PW1AN
Flash: 500088-001484-7
Im trying to attach an O5 Control Head
62Truck
Ordinary Subscriber
Uranus
TIB should work. Do you have all the proper cabling for the control head? At a minimum you'll need the control head cable with the blue maker on them, and the control head power cable, has the red maker on it.
nokones
Sun City West, AZ
I don't see the Flex cable in your picture. There are two flex cables, one for High Power, one for Mid Power. The Flex cables are marked accordingly and the correct Flex must match the radio. What error code(s) are you getting?
nokones
Sun City West, AZ
I just realized that I had a spare Mid Power Flex and I noticed a XTL2500 Mid-Power Flex on eBay and the part numbers are different. Just to be sure, tomorrow, I'll check my XTL2500 and XTL5000 mid-power radios and see if they are the same or different Flex cables. I don't think they are the same and if you have a High Power XTL5000, I'm sure that there would be a difference between the XTL2500 and XTL5000 High Power radios.
KK7GKG
Salt lake county
I have all the cables for it except the connector between the Brick and Tib
The High Power and Mid power Tib cables are different
The Mid Power cable for an XTL2500 should work on an Mid Power XTL5000
The XTL2500 cable I used was the Mid Power one
KK7GKG
Salt lake county
Let me add it is the high power version
I’m trying to add an remote O5 Head
nokones
Sun City West, AZ
You "May" need to do a Firmware update for the change of the controlhead type for the subject radio.
I checked the Flex in both of my Mid-Power XTL2500 and my XTL5000 radios. They do use the same Flex cable, part number 84009527002, for both the Mid-Power radios, but one of my Mid-Power XTL5000 radios, uses a Flex that is totally different in appearance, with a different part number, 8464459H03. I believe that may have something to do with the radio with the different Flex part number has the Secure Feature and as noted on the 84009527002 Flex Cable, "Not to be used Secure Interface Boards".
And, as for the TIB cable, you will need the XTS5000 High Power Flex cable. The part number is: 84009526001 and the part is still available from Motorola for about $60.00 not including shipping and tax.
This is the Flex you need:
