XTS 2500 "Clicking" Mystery
portroyalbirdy
Central PA
This one is a mystery to me, but my brother has a Motorola XTS 2500 (used) that does a "pulsed clicking" noise on analog channels, and we have no idea on the cause! It happens in vehicle, out of vehicle, different vehicles. Used in or FD. It's only on analog that it does this, P25 Conventional is fine. And I/we would see if anyone would have any ideas/causes/fixes, or if it's a hardware issue, and/or due to age (We believe it's an older gen 2500) It IS also using an aftermarket battery, but from a brand we've used in the past with/on 2500's before, but we know you can sometimes get a "bad" battery!
Thanks in advance!
(Click Here) for the combined audio file.
RFI-EMI-GUY
You probably have priority channel scan set up in one or more modes. Based on the recording I would hazard a guess that the repeater input is set up in the non priority scan list and the repeater output is in priority scan list
portroyalbirdy
Central PA
The recording is from a live feed hosted by a feed of mine. Feed is stereo but the channel the audio is recorded on is the Dispatch channel which the feed mobile is "parked on". I just chose the feed audio because it captured it. It can be heard on pages, scanners, etc.
I (think) this also occurs when the scan is turned off on the 2500, but will check/test next time it's used.
I believe, but not 100% sure it's set up that the 1st Priority is User Selectable (whatever channel you're on) and the the 2nd I think may be the Dispatch Channel or Safety Channel (Repeater Output) but again, not 100% sure. A friend of mine does the programming.
That would be the thing to test.
as RFI said above, this is almost always the priority scan and the clicking is the 'lookback' when it checks the priority channel. I've got L3Harris, Kenwood, Icom and Motorola radios that all do the same thing.
