XTS 2500 Help
ffjsh
Dartmouth MA
I have an XTS 2500 and i have it programed the way i want. I have a few questions and i need help with it.
My radio guy at work cant figure out these issues.
(1) I have a digital frequency programmed into my radio, when i put it to that channel my radio beeps 3 times and the screen says "Key Failure" I do not know what the issue is. I have a few digital channels along with all analog frequencies and this channel is the only one that does it.
(2) The same digital channel, when i scroll to this channel i can not scan anyone at all. It will not allow the "Z" to come up on the screen but if i change the channel i can scan anything thats in the scan list including that digital frequency.
(3) When i got the radio i was able to make my own scan list on the fly by pressing the purple scan button and putting it in to scan mode and then picking what i wanted to scan and not. Now if i put it into program mode when i try to lock or unlock channels it just beeps and will not allow me to change the scan list.
The digital frequency i am talking about is Dartmouth Ma police dept.
Please someone help me or point me in some sort of direction
mancow
N.E. Kansas
That channel is probably assigned to a conventional personality that has encryption slaved to on and no scan list defined.
mancow
N.E. Kansas
Not trying to be rude but without a basic knowledge of the CPS software it's impossible to explain in too much more detail. Do you have the software handy?
RKG
Boston, MA
1) Your radio guy has programmed the Dartmouth PD channel for strapped encrypted, but no key has been programmed (if using ADP) or loaded (if using hardware encryption). Have uncheck the "Secure Capable" parameter and strap this channel for clear.
2) Somewhere in the programming process, your radio guy has failed to enable scan and select a scan list for the channels that will not allow turning scan on. Point this out to him and he'll see the issue.
3) The scan list associated with the channel you've selected when you try to go into scan program mode is not set for "User Select" on the non-priority members, or the scan list is full when you try to add a channel.
I hope you don't take this the wrong way, but if these issues are beyond your "radio guy," methinks you need a new radio guy.
ffjsh
Dartmouth MA
i dont have the software in front of me, thank u guys for u help i dont take any of this as rude. im just looking for some tips so i can get this radio working 100% right
