XTS 2500 programming
ridezfast911
Good evening all. Im a first time radio programmer and am programming my XTS 2500 via the CPS, and I have a couple questions.
1) I am trying to set the radio up so that it transmits an id when I key up. What is the best way to do this? Also, are there any character limitations as to what i can and cannot use?
2) Trying to set up the radio for narrowband seeing as most services I work for or communicate with have either narrowbanded or are about to very soon. I think I have it figured out, but I just want to make sure. Im viewing the channels table under the zone view, and im seeing a drop down option of either 25 or 12.5 kHz under the "Tx Opt Channel Spacing" column. Selecting 12.5 kHz in this column will narrowband the channel appropriately, correct?
Thank you to everyone in advance for your help.
GM
Do you want it to transmit an MDC type ID, a DTMF style ID, or a P25 digital mode ID number? You can do the MDC and DTMF at the beginning, end, or both sides of a radio transmission in analog mode. The P25 mode will transmit the ID number throughout the time the PTT is depressed. Either way, each channel has a personality set to it, and you have to go that way. Gone are the easy days of programming radios. But each section of a personality will have a choice for MDC, DTMF, or ASTRO, which is the P25 digital mode.
With the narrowband, you want the section where it lists either 2.5 khz, 4.0 khz or 5.0 khz transmit deviation I belive it is. Select the 2.5 khz, which will then show the 12.5 khz in the section for channel spacing. If you go to select the area where it shows 12.5 khz, 20.0 khz or 25 khz, it may show an eyeglasses looking figure, and will not allow you change the setting there.
That should start you off in the right direction. Others will chime in and give you more detailed advice as they are more experienced than I. :)
ridezfast911
Id want a P25 style ID. I went into the personality for the channel I want the ID on, and I cannot see where to set up the transmit id.
N4DES
Retired 0598 Czar ÆS Ø
South FL
If the radio does not have Soft ID, you will not be able to do it if your looking to send an Alpha type ID in P25. That can be found under the Astro Configuration, but only if that feature is turned on. If it isn't turned on then the tab will not exist.
If you just want to send a P25 numeric ID, that is under the Astro System under the General tab.
