XTL/XTS5000 XTS 2500 scan list?
I have been trying to set up a scanning list to no avail. My scanning list shows only Z1 channel one as being programmed. When I add more channels to the scan list they don’t save on the list. The radio scans channel 1 but nothing else even thought there is a Z next to each channel on the radio.
I have spent many hours looking for a solution online and in manuals. Any help would be appreciated.
prcguy
Under CONVENTIONAL PERSONALITY select the SCAN tab and tell it what scan list you will be using. Then under SCAN, select SCAN LIST then choose what channels you want and they must be from a personality that points back to the scan list you are creating. Then under RADIO CONFIGURATION then DISPLAY & MENU, go to MENU ITEMS and add SCAN if its not there already.
If you have FPP enabled you will have a crap load of personalities and each one that is married to a channel will have to point to your scan list.
