So I am playing with my radio understand the soft ware I think at least, just curious why has someone not came up with a 15 pin Vga male programming cable yet??
Wait what?
Where does a 15 pin VGA cable come into play with respect to programming?
All programming with a Motorola RIB is done via the RS232 serial port which is 9 pins (or in some cases, 25 pins with older machines). A VGA port is only for video to connect to your monitor, it has nothing to do with programming what so ever - such an adaptor would do you no good.
There IS a 15 pin connector on the RIB that is used to connect to the computer, however it isn't a VGA type connector. It is used to connect to either the 9 or 25 pin serial port. If you look, a VGA connector is a 15 pin three row connector that is the same physical size as the 9 pin serial connector. The Motorola RIB needs a 15 pin two row connector that is the same height as the 9 pin serial connector, however wider.
For proper nomenclature, a VGA connector is called a DE15 where as the RIB connector is a DA15. The serial port is a DE9. The "D" is reference to the series whereas the second letter refers to the size (A through E). The numbers refer to how many pins are present.
