xts 5000 modle 3 trunked programming
wv
#1
yes when I edited my scan list to add zone 8 channel 1 to scan it will shows it in the scan list after I write the radio but wont work but all the other I put in work for some reason it the only zone 8 and channel 1 also when I am on that zone 8 and channel 1 I can not even put the radio on scan I am not sure what going on thanks in advance
Skypilot007
Medford, NJ
#2
Try again in English please. :confused:
wv
#3
okay sorry I added all fd channels to my scan list have 8 county's total well all of them work great in scan except for the 8th county but it shows it on the scan list but it will not scan it also if I am on that 8th county I can not even put the radio in scan mode for some reason all the other I can
wv
#5
okay how do I correct that if you have time to tell me my comm center programmer has no idea because they just through the code plug in and done
wv
#7
and also i can go to that zone and channel and talk to the comm center and listen to them fine just wont scan that channel
Forts
Ontario, Canada
#8
If you aren't familiar with programming (and it doesn't sound like you are) it might be easier for you to post the codeplug and let someone fix it vs someone trying to explain what to look for and how to fix it.
Basically you need to see what conventional personality is assigned to zone 8, channel 1 and make sure it's in the proper scan list. Then you need to check that conventional personality and make sure the scan list is assigned to it. Kind of scares me that the programmer who made the codeplug doesn't know how to fix that....
wv
#9
we are on the wv sirn network they just through in the code plug and that's it i put the channel announcement on it because they didn't know how
Forts
Ontario, Canada
#11
It is an easy fix if you know what you are looking for. Like I mentioned it's concerning that the local radio techs don't seem very skilled.
NV
#12
Basically each channel (mode in the programming software CPS) has to have a personality assigned to it. the personality assigned to your channel that doesn't scan sounds like its not set up to scan the Scan List.
Skypilot007
Medford, NJ
#13
Um..yeah. They just handed over the programming computer and cable to a fellow who can't put together a readable sentence with proper grammar. :roll:
wv
#14
well thanks to me801 and forts the trunking personality was not set up to scan thanks for all the help working great now thanks you
