XTS 5000 Trunk programing
#1
Hello, I am looking for a guide to program trunked 800 MHz startcom21 / interop made easy. Looking for the process my basic understanding is make 16 personalities, then make a 16 Zones. but what actual data in needed to program? is DEC, HEX, Mode, Alpha Tag etc. enough?
I haven't seen any new information out there since 2013, so I thought I would ask, since there are thousands of these radios out there now. I got one for $275.00.
Looked at CPS, tutorials just way to much information to digest at once and retain, looking for step by step guide.
BTW, not looking to do anything illegal. FYI.
Thanks.
sfd119
#2
Just so we're clear....you're looking to add an XTS 5000 to the StarCom21 statewide system, yes?
Take it to a radio shop. If you are asking what information is needed to do this, you do not have the experience needed to even begin to attempt this. Moreover, you can cause serious system issues that can affect other radios on the system. Once the System Admins find out, your radio will be disabled.
Not trying to be rude here, but this is a huge no no.
Skypilot007
Medford, NJ
#3
Texas
#4
It's pretty clear KC9DAQ wants to do non-affiliate scan of the system. All the information to do this is out there, you just have to read up on it and learn how to do it. There was instructions on another site but they are offline it appears. There is good information on here too you just have to sift through all the rif raf to find it. Try here: http://forums.radioreference.com/motorola-forum/200563-programing-trunked-radio-monitoring-only.html
What neither tell you is that you first need access to a system key.
Communications Support has officially closed its doors.
#5
XTS non-affiliate scan
correct, looking for the correct information out there, cause there is a lot of miss/incorrect information. also from what I read you can program interop channels but need to verify. also looking on how to program the UHF XTS 5000, thanks guys
