XTS & APX Encryption question
motobot213
Ø Manager
LA
Few questions:
If a radio such as a XTS5000 or APX8000 has encryption loaded into it and then if it is reprogramed in CPS will that clear the encryption keys?
If yes is the case is there a way to prevent that from happening?
Also if a battery is removed from the radios while on will that also clear the encryption keys?
zacabo
FL
Few questions:
Reprogramming the radio will not clear out the loaded encryption keys. Removing the battery could clear the keys depending on if the radio is programmed for infinite key retention or not. Once you read the radio you can see how the key retention is programmed.
motobot213
Ø Manager
LA
Ok Got it. However last time I programmed my XTS5000 after it was key-loaded all the keys were wiped and I had to bug to get it re keyed.
motobot213
Ø Manager
LA
I checked the radio and infinite key retention was checked. Any other ideas?
