XTS portable - what type of antenna end fits?
V188
If I wanted to use a mag mount occasionally in my vehicle with my xts3000 what type end would I need? Ex: RCA,n, rj, uhf, bnc, etc as example. What screws into the xts antenna mount?
Thanks.
Fizz306
Long Valley, NJ
i'm hoping this will help point you in the right direction. i'm assuming that your mag mount is bnc.
BNC Adapters
first item at the top, item # SMF-BNF BK. i've used this to hook up my XTS1500 to my ST2 in the home, as well as mag mounts in the car.
wrc1045A
Beavercreek, Ohio
rescue161
KE4FHH
Hubert, NC
I repair the SMA mounts on XTS2500s DAILY. The SMA junction is attached directly to the PCB and they are very weak. Adding adapters to the XTS2500 is going to cause issues. XTS3000/5000 are a little better, but I would not recommend using any type of adapter on these or any radio for that matter.
Always use the correct connector (not adapter) and good quality feedline.
