XTS TX High Power Fail
#1
Hello All - I have a batch of 50 XTS 2500 that I'm running through the AeroFlex Digital Radio Test Set with the auto test for the Astro 25. During the test I get some radios with TX power fail in the High, Mid and Low level while others run through without an issue. Is there something I can adjust with the AeroFlex or is there a internal problem with the XTS.
Thank you,
MADOC
#2
PHYSICALLY inspect each radio internally. Common failure on XTS2500 is the antenna connection to the circuit board.
Make sure you have the correct battery eliminator for the 3920 test kit and it is set to the correct voltage and current limit.
PALM BEACH, FLORIDA
#3
Thank you,
MADOC
But doesn't the Aeroflex correct the issue? I've seen where settings are out of spec, & the Aeroflex automatically corrects it.
#4
One would think it would. The auto test and alignment works well on some of the units. I have about a dozen with TX High, Mid and TX Low Fail AMD RX Ber Fail. Does anyone know what RX Ber is? I'm thinking an issue with the XTS it's self but I'm not sure where to look.
PALM BEACH, FLORIDA
#5
I recently bought some XTX2500's. 2 UHF, & 2 900's. Both UHF radios were ex military, & they wanted the low power settings to be 1/2 watt, even though spec was 2 watts. So when I brought the radios to my friend's shop, & ran them on the Aeroflex, they both failed at the low power setting. The Aeroflex then set the low power settings to 2 watts, automatically w/o having to do anything. The 1st 900 radio was OK, but 600Hz high, so the 3920 retuned it automatically, & it was then 6 Hz high. But the 2nd one could not get into repeaters, although 927 rx/tx was fine. Ran it on the 3920, & it turned out the dev/bal was 7% out of spec on repeater input freq's. Again the Aeroflex corrected, & retuned the radio to spec. So there was no manual tuning involved. Just push a button, & the radio reads the specs, & retunes if necessary. It even printed out a report of all the specs. Pass, fail, & retune. Like a report card for the radio.
rescue161
KE4FHH
Hubert, NC
#9
I'd say that 1 out of every 10 that come through our shop have to have the SMA replaced due to them being broken off of the board. This will cause the power output failure that you describe. On some radios, even after repairing the SMA, the alignment still fails. More than likely due to continued transmit into an open load, which destroys the PA. MAKO board replacement is not cheap, so inspect that SMA closely.
dpcain
MD
#10
Ensure the settings are reasonable for power calibration. I have had the same issue with certain monitors due to base-calibration files having unreasonably high power output expectations.
