Xts2500 antenna connector
firebell9137
Hi. I have a vhf xts2500. Can this radio have a BNC connector for the antenna? Or is there a high gain vhf antenna? Mainly 154.370 154.190 151.130 151.235 154.3475 155.340. All analog
You can get BNC adapters that will go in the SMA, however they are usually intended for bench testing only. Using them as your normal setup can put a lot of strain on the antenna jack.
There are high gain VHF antennas, but I don't recall the part number off the top of my head. Analog/digital, it doesn't matter to the antenna.
firebell9137
ok thanks. can the xts2500 do Linear Simulcast Modulation?
GTR8000
NY/NJ Database Guy
BEE00
You do understand that LSM (CQPSK setting) is almost exclusively for P25 simulcast trunking, rarely for conventional and certainly not for analog, correct?
What exactly are you trying to listen to, and what makes you sure that it's LSM?
firebell9137
Kenosha, WI sheriff dispatch 155.955 nac270. Someone told me they were linear. I take it off scan and monitor it and it Rx perfectly with that setting but i put it on scan and nothing. However it scans on my uniden 436hp scanner.
GTR8000
NY/NJ Database Guy
BEE00
The GTR8000 and most other modern P25 repeaters have linear amps, but that doesn't necessarily mean they're transmitting in LSM. Regardless, the radio shouldn't have an issue receiving C4FM or CQPSK even if the settings are reversed in the codeplug. The key here is that you can receive them with scan off, which means something else is going on with the radio. When was the last time it was tuned/aligned?
firebell9137
Quite awhile.
firebell9137
I have the tuner that came with the cps. What should i do?
firebell9137
I have the tuner that came with the cps. It's the most current version of both.
FFPM571
Nashvillle
Kenosha is Conventional P25 They have a good signal as I could hear them from South and Central Lake County IL . It sounds more like a Scan programming issue
firebell9137
Thats what im thinking. But everything is in the scanlist and assigned in the conventional personality.
KevinC
Encryption
Super Moderator
I'm everywhere Focker!
If you’re sure the scanlist stuff is correct it could be an alignment issue. But I’d triple check to be sure CQPSK and not C4FM is what you have selected and be sure it’s the correct personality.
firebell9137
It definitely is correct settings and scan settings. How should i get it aligned?
firebell9137
The Kenosha police dispatch channel works in scan but not sheriff or pppd. I tripled checked it
