Thanks for your response, I am clear on everything except the zones. Can I add certian Personalities to a zone. For example, if I wanted to add a frequency to a radio can I select what zone that I want it to appear in?
Yes and No.
IfF the Personality (Channel) you want to edit is in a Zone has been "FPP Protected" from the CPS then Yes, if Not then No.
Lets assume a new XTS2500 with only 1 Personality (Cheannel) is setup in Zone 1 (Name= UHF Simplex rx=446.000 tx=446.000 etc.....)
There is no way to protect a Zone from the radio. It must be done via the CPS.
So lets assume you now have it connected to the CPS. You will see in "Conventional Personalities" only one entry as listed above as well as "Zone 1" (or whatever you call it) with one entry.
Now IF you "FPP Protect" Zone 1, it will automatically add 14 personalities in both "Conventional Personalities" AND "Zone 1". (It will put in valid info in those entries.)
So all 15 Personallites in Zone 1 are now able to be edited!
If you now add a 16th personality it will go to Zone 2 and be the 1st entry in Zone 2. If you add for example 5 personalities, they would be in Zone 2, personalities 15 thru 19.
IF IN THE CPS YOU DID NOT "FPP PROTECT" Zone 2, YOU WILL NOT BE ABLE TO EDIT THESE!
If you once again go into the CPS and tell it to "FPP Protect" Zone 2, It would keep the ones you added and add now create 30 "Conventional Personalities" total and fill both Zone 1 & Zone 2. You would be able to edit both Zones info.
Make sense?
