xts2500 keeps txing with speaker mic
tbendick
Nyc
Have a xts2500 that keeps keying up when a speaker mic is connected. If the radio case is open everything is fine. Once the radio is reassembled the problem starts again.
Also seems to stop when the antenna is removed? Radio will get stuck in TX ,unscrew the antenna and it stops.
Any ideas if something is getting shorted out inside?
Everything is fine without the speaker mic, only issues are with the mic connected.
gewecke
Banned
Illinois
It sounds like the emergency button is pushed?
73,
n9zas
Go on batlabs find the schematic for the external mic. Ohm out the pins and look for a short.
Sound like the PTT is shorted out on the external mic.
tbendick
Nyc
Tried one other mic from an xts3500 (with emerg button) but it did nothing
Mic works on ht1000 with no issue. Will check the pins with the meter just in case
