XTS2500 menu options
Queens, NY
#1
I programmed my radio today by adding a new zone with 30 channels.
I put "CHUP and "CHDN" on the menu options but it won't write it to the radio.
Any idea why?
Queens, NY
#3
I had to add the "Chan" button and then use the right arrow to navigate to the other 16 channels in that same zone.
AFDFireMedic
Agawam, MA
#4
I was having the same issue, I spoke with Motorola and it's a firmware release issue. The CHUP/CHDN buttons won't work in versions prior to R12 (mine are R09's). You can check your model number, if it ends in "AN" R09 is as far as it can go I believe.
