Eaton90
- Joined
- Oct 26, 2010
- Messages
- 46
Hi everyone!
I tried to program my XTS2500 to be able to send Qick-Call II calls to other radios. In the personality window I set the signalling type to Qick-Call II, in the Qick-call II layout of that personality I checked the "Selective call encode" and "selective call decode" boxes. Call system is set to "System 1" and this system really exists. CALL item is added to the menu selections.
Nevertheless when I turn the radio on and select that channel, I can't find the CALL in the menu of the radio, thus I assume this feature is inactive for that personality.
What can be wrong? When I change the signalling type to MDC and check the same boxes in the MDC layout, everything works as it is supposed to...
And one more questions about the Astro signalling. I have another XTS 1500 radio and when I make it transmit I can read it's ID (86524) on the display of the XTS2500. I try to send a call to my XTS1500 from XTS2500 so I select CALL from the menu and I'm asked to select or dial the ID of the target radio. I dial 86524 and push the PTT. Nothing happens to the XTS1500, it makes no sounds, it just receives as always. So what's the purpose of Astro signalling or am I doing something wrong?
Thanks in advance!
Thanks in advance!
