XTS3000 Battery Display
billy5715
Boston, MA
Is there anyway to get the battery gauge to displaying the LCD? It appears during start-up/self-test but I can't get to appear after that. I have looked all through CPS and have found no solution.
Thanks.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
No, the XTS3000 doesn't use the battery gauge at all.
You'll need an ASTRO25 radio if you want a battery gauge.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
This is not true. The battery "gauge" or icon is shown, flashing, when the low voltage limit is reached.
It is correct to say that it can't be set up to show battery life full-time.
N1GTL
CT
I went through this several months ago and if I remember correctly you need an Impress battery for the battery icon to work. Also, if you charge an Impress battery in a non-Impress charger a few times, the icon will no longer work.
N4DES
Retired 0598 Czar ÆS Ø
South FL
Impres battery or not, the battery guage will not show in an XTS3K. Has to be an XTS5K.
It will only flash when the battery is low in and XTS3K.
ResQguy
Meh
As a matter of fact, if you use an Impres battery on an XTS3000 with old firmware you will even get premature low battery alerts! I can't bring up the revision level you need right now, but its something to be mindful of.
mm
oregon
There was a firmware version 6.X.X something, the one that did P25 9600 baud trunking and it had the fuel guage.
We used to have some of these XTS3000, P25 radios but we upgraded most if not all of them to XTS5000's years ago and I doubt we have any lying around but If I do find one then I can program it up and take a picture of it.
Mike
immelmen
I have a R06.X firmware 9600 trunking xts3000.
No dice, as others have stated, its not an option on any 3000. You have to move to the 5000.
