XTS3000 Display not updating
rbluesky
Hi I have a xts3000 and I cant get the display to update when I modify the code plug. I WANT ZONE, NUIS , PWR.
I GET ZONE, DEL PWR. And DEL is Not in the List ? What am I doing wrong. .yeah I remove DEL AND add NUIS. And DEL comes back!! VHF radio has astro
Ron
ElroyJetson
Still check the menu options. They're configurable whether the radio has trunking in it or not.
According to my not quite perfect memory, DEL is not in the list. It never was. It's built into the radio. When you have an editable list, like a call or scan list, ADD and DEL are always going to be available. Not in the software, it's in the radio. Motorola does not make you add in ADD and DEL when you have an editable function in the radio. It's automatically added.
rbluesky
Ok but how do I ADD NUIS TO the display
It does Not show on the display once I add it and write to the radio
rbluesky
Care to share how!
for some reason I guess older flash code only show DEL and newer flash codes show NUIS but if you look carefully and you pick Nuis/DEL they're the same thing !
