Xts5000 mdc1200?
Pine Ridge, SC
#1
Hey guys I got the Astro25 CPS today and I'm trying to program MDC-1200 into 4 conventional analog channels. Can someone tell me how to do that?
#2
In cps in your radio wide, if it's a display model check the tab and in there locate id display. Then go to your conventional systems, go to mdc then set your post or pre, other options such as radio check, inhibit. Then go to your conventional personalities and ensure the muting condition is and/or and in mdc tab or. Set the mdc profile for the perosnality.
