Im having trouble programming my XTS5000. I have CPS 20.01.00 and a serial programming cable and usb to serial adapter. When I try to read the radio I get "Open Radio Failed. Error context: 24. Status: c000039e". Im not able to find what the serial port settings need to be or anything to help me.
Any help would be appreciated.
Greg
I guess the first questions is, have you ever programmed this radio, on this computer, with this cable?
You say, "serial programming cable, and USB to serial adapter"....are you running the RIB box? Or is the cable rib-less?
Most "failed to communicate" issues are related to Windows. If you're running an adapter, make sure the drivers are updated. Within the CPS software, under "view", is the "options" menu. Within that menu, are the port selection settings. You can try changing the port there (and use Windows device manager to figure out what port is assigned to your adapter).
Hopefully some of this helps!
Paul
