XTS5000 Programming
alien11
Hello All,
I'm trying to read my XTS5000 using CPS R.14 , but received the following error:
This Radio is not supported by this application.
Error Context:a, C0001013
Any suggestions?
bezking
On the Road
That means your radio has been programmed with a CPS version newer than 14, you need to upgrade in order to read that radio. The current latest version of Astro25 CPS is R16.
mbnv992
AZ
What changes were made compared to V15 ? I have Astro25 Version 15 currently.
IAmSixNine
Dallas, TX
Radio not supported by this application is different from the Version not supported error.
I could be wrong but to me the error is different.
mikewazowski
Forums Manager
Oot and Aboot
The error is usually Codeplug too new when you use an older version of CPS.
In this case, the CPS doesn't seem to recognize the radio as being one it supports.
Astro25
Chicagoland
As Mike pointed out above, perhaps you've got the wrong software package? Make sure it's Astro25 Portable CPS; XTS3k/ASTROSaber CPS won't do and would produce an error like you originally posted.
IAmSixNine
Dallas, TX
Thank you Mike. It was bothering me i couldnt think of it. Codeplug Too New For Applicatoin is what i was thinking of.
XTS3000
I got a simular error when trying to read an Astro25 mobile with the Astro25 portable CPS.
alien11
Thanks for the input guys. Turns out I was using the Astro 25 mobile instead of the portable cps. Both are installed on the machine but the shortcuts were renamed by the previous programmer.
john1158
XTS5000 CPS password
I need help. My XTS5000 has the cps password enabled so I can't read it. I am using CPS ver 15.0 and have looked using my hex editor. I enabled it on another 5000 and found it but each time I look it is in a different place.
rescue161
KE4FHH
Hubert, NC
What hex editor are you using? Use WinHex.
1) Open CPS and read radio.
2) When prompted for password, stop.
3) Open WinHex.
4) Under Tools, click "Open RAM".
5) Select Patport (Should be near the bottom).
6) Select Primary Memory and search for this string: "\Microsoft\Windows\CurrentVersion".
7) You may have to keep hitting F3, but the password will eventually show up.
john1158
Xts5000
I've done all of this several times and I think I have a few new gray hairs. I'm using winhex.
