XTL/XTS5000 XTS5000 vhf best antenna?
BlackSheepDue
Naples, ME
I currently have my apx7000 vhf/7-800 and xts5000 vhf sitting in front of me. With the 8” vhf helical antenna on the xts it was having a hard time decoding p25 traffic on the edge of it’s range. I swapped out the antenna for the apx vhf/7-800 antenna and it receives noticeably better.
This seems counter intuitive to me that a dual band antenna would work better than a dedicated vhf antenna so I’m wondering what antenna people have had the best luck with on a xts5000 vhf.
Thanks,
Thomas
Giddyuptd
Here and there
Many use what you have the long whip vhf/7/800 one. If you mainly use 7/800 a whip 7/800 may work. I believe using the vhf /700 apx antenna on it won't hurt it.
Just be cautious on the xts2500s, 1500s. The sma are common to break off inside and need reflow. I wouldn't recommend that antenna on the 2500s and 1500s.
K2NEC
NA
I have the PMAD4088 and the PMAD4067 and out of the 2 I like the APX (PMAD4067) antenna a lot more. Looks better and performs a tad bit better.
Ant9270
The Green Weenie
I like the Wideband PMAD4088 Antenna. It seems to pull in the best signal out of all the antennas I’ve used. However, the PMAD4067C Is amazing as well.. If not better. A bit more forgiving on the size as well as it’s not constantly poking you.
K2NEC
NA
+1
cmdrwill
So Cali
That is what I use on my Jedi VHF +1. I think these later antennas are a better design.
GTR8000
NY/NJ Database Guy
BEE00
PMAD4067 is the MotoTRBO 6000 series antenna, not APX. That model covers 136-147 MHz, so unless you're using the radio exclusively on the 2m band, you'll probably want the PMAD4068, which covers 147-160 MHz. Both models are also GPS capable.
The PMAD4088 is also from the MotoTRBO 6000 series, covering 136-174 MHz (no GPS).
The APX single band VHF antenna is NAR6593, covering 136-174 MHz with GPS capability.
