XTS500R 380-470 conventional personality delete.
P25Radio
Oceanside Ca.
I have a question if anyone can help. I have a a radio that has 240 conventional personalities in it. When I try to delete them I can not, I can add them all day long. The RED X is not highlighted as the green + mark is.
It is the same for zones and channels I can not delete the unwanted ones.Radio is not set for trunking. Here is the flash code.5A0401-000307-3 any ideas I am kinda lost. Radio does have FPP enabled. I am fairly versed with CPS but this one has me stumped. I do not need 240 just 1. Help please!!! I can send a code plug file on a PM if requested to look at.
Project25_MASTR
Millennial Graying OBT Guy
Texas
You nailed it in your initial post. FPP in the flash means you have 240 Conventional Personalities to start with.
To get down to 1 personality, remove FPP from the flash.
Sent from my SM-T713 using Tapatalk
Project25_MASTR
Texas
Most of us won't mess with it and use other, cleaner methods of management.
For example, I tend to preprogram common pairs for FM then use MPL and leave it in a travel zone. I found that of the 653 2m repeaters in Texas, almost 60% use 1 of 15 pairs and 1 of 5 tones.
UHF is even more interesting because you have groups like the Armadillo and Cactus Intertie's which have a handful of channels that they run all sites on. Armadillo for example, has 8 channels and they typically hop around on one of 5 PLs.
N4KVE
PALM BEACH, FLORIDA
On my XTS2500 with FPP, I only allow FPP in ZONE 1. So 16 personalities for that ZONE, & 3 more for the rest of the radio. I believe if you go to a personality, & turn off FPP, you can then delete that personality. They DID get FPP right in the APX line.
